I hope someone can shine some light on this. I bought a 02 Prairie 650, took it for a ride around my lawn and the dirt was a flying. I had to put it in 4wd to get out of the hole it dug on flat dry lawn. I pulled it into my garage and tossed a jack under the rear and noticed the RR will spin free but the LR turns and inch and the whole swing arm moves like its in gear. It shifts good, starts good and runs fine in 4wd. I checked the brake and it doesn't appear to be holding. Thanks for any help I can get
The '02 650 is a solid rear axle machine, so if one wheel is spinning and the other isn't turning at the exact same speed, there is a serious problem with your axle, diff assembly. You need to tear it apart and assess what parts you need as there is something definitely wrong there.
