Hi all. I am new to the forum but have searched hi and low for an answer. I recently did some repair work on front a arm bushings and replaced the radiator on my 02 prairie. I did wash it some when I had it apart but steered clear of the electrical compartment. Long story short I have it back together now but when I start it, it will run for 5 seconds or so then quit. I pulled the fuel hose and keyed the switch. It pumps into the can for 5 seconds then quits. Does this sound like a relay or pump problem or can some one steer me in the right direction? I'm sure this is a newb question but electronics are not my strong suit. I do have a meter for testing but not sure where to begin that phase at this point. Thanks
Cephus0331
Discussion Starter #2
Anybody have any ideas? I really want to get this thing goin. I use it a lot this time of year for work.
I would check and make sure you have a quality spark. You have have got some water on the plug wire that found it's into somewhere it's not welcomed.
Good Luck
