Typically if your CDI is bad It will not fire or have a really intermitten spark. The Best CDI's are Dynatek, however they are costly. The majority of the restof the aftermarket CDIs are made by Procom and have a strong reputation for failing very fast. No you dont need to rejet for a CDI. But without getting stronger valve springs such as the DRZ400 springs I wouldnt get a CDI that allows more than 2000rpm over rev. The Jet kits are not a rebuild kit. They are usually just jets and an aftermarket filter. Rebuild kits are usually new seals, o-rings, bushings for the flap and needle and diaphram assy. The adjustable clip needle is the only thing worth a crap though. If your carb needs a rebuild, you may want to look into getting a FCR39 off the YFZ450. It is way more responsive and will out flow that 36mm stocker any day.
