Is there supposed to be a gasket for this? I took mine off to check out my reverse lockout and someone in the past put rtv every damn where inside there. when I went to get the shift seal the parts guy said I should use rtv but when I look at the repair manual here it shows a pic of a gasket and putting rtv over everything looks like a pita.
btw, the problem wasnt my shifter seal, it was the collar behind it that keeps the shifter shaft from flexing. it was pushed back and nothing was holding it in place. anytime you'd shift the rod would bend letting oil out.
Thanks, thats what I was hoping. Back to the parts store and prob wont get it till monday. I need 2 atvs it seems, one to fix and one to ride while parts are coming in for the other.
