ok guys im in a pickle lol after months of talking my friend into buying a quad he finally goes for it and picks up a '05 kfx 400 claiming to have the bore kit to a 440 and a slip on exhaust. i believe that's all for $1800.. runs like a champ, i drive a 250 (ill leave out the model lol) and i say it it runs great def has more power than mine. ....but its overheating and to the point where it is boiling occasionally, mainly when hes nailing it or donuts or getting unstuck. order of approached
1) i checked for air leaks (never seen so much air crap on a quad) - no change
2) changed thermostat - no change
3) tried diff coolant started with ice i think, it was switched to the green stuff 50/50 - no change
4) changed head gasket- inspected cams n lifters, didnt mic the cam but the lifters wernt concaved. timing chain and gears look great. set the timing to i believe was ex 2 up intake 3 up on tdc comp
issed: - NO CHANGE
what am i missing? can the water pump be jacked? or should i retard/advance the timing? but like i said aside from overheating it shows no problems starts right up runs flawless and has never shut down
appreciate any help i can get, all the threads i look at have other issues that can be causing problems
