21 - 24 of 24 Posts
Discussion Starter · #21 ·
It did idle with the choke on. I believe it would start with the a/f screw turned in. Idles briefly with carb cleaner. Ive disabled the entire carb. Sprayed it with carb cleaner threw all the ports. Blew compressed air threw all the ports. There is fuel coming out of the line when i pull it off the carb.
It ran with carb cleaner IN the carb, or sprayed down the bore (venturi) of the carb?
If the float level is too low, there won't be enough gas in the carb to reach the jets, and it won't run.
Got a 05 prairie 360. Sat for a while just rebuilt the carb. New gas. It will start and idle with the choke on. Once i turn the choke off it idles high for a couple second and then slowly comes down to the point where it stalls out. If i rev it once it gets low the idle jumps back up and then slowly comes down again. Any ideas?
I have a 2004 kawi prairie 360. Nice machine. I did all the carb stuff. This one seems like it vapor locks
21 - 24 of 24 Posts
