Bought this ATV about 3 days ago got it for 1200 dollars because it needs a muffler and it WAS STUCK IN 4x4
The Issue is the this I tried removing the actuator but for some reason it just wouldn’t come out easy ! I then just screwed it back on and decided to take the actuator cap off so I could manually turn it to get back to 2wd, somehow after turning and turning 1000times it did go only 2 wheel drive, then I tried turning it again to 4wd instead it was just making a whining/grinding type of noise just by me rolling itback and forth. I proceeded to take try and take the actuator out which I did with a lot of wiggling back and forth and this is what I got
75412
now my concern is what happened ??? Please helppppppp!! Another thing is when I screwed the Actuator back in it kinda cracked the housing
You need a new actuator. They are about $260 new. Cheaper used ones on Ebay.
Before you bolt the new one on, make sure the little sliding collar inside the diff moves freely.
Or go with the Sgroi 4x4 aftermarket kit instead of a new actuator. About the same price as a new actuator.
  • Like
Reactions: JstWantoRide
