i am not getting any fuel to my carbs. i think it may be my fuel pump but was not 100 % sure. i was wondering if anyone had any problems like this if it was a fuel pump or something else. any help would be appreciated. thanks
Could be the fuel pump but it also could be that the Fuel tank air vent is block or even the fuel line could be clogged.
check..........
Pull the fuel line at the carbs route it to a container........turn the engine over and see if the fuel is flowing.........if its not make sure all the vacuum hoses on the engine are on where they go with no cuts sharp bends etc..
The air flow in these hoses is what makes the fuel pump pump.............
Check all the simple things first.............
i tried taking the hose off of the carbs no feul comes out so now when i get home today i will look for the vacuum lines. thanks
thanks for all the help i got it going i changed the fuel pump. thank god for the ole parts bike!!
