1 - 8 of 8 Posts
Hey I’m new to the brute force but I just installed an 840 kit running stock heads and cams with a moose power module and hmf exhaust I ran it last weekend and it drove fine but bogged at full throttle and didn’t have half the power I was expecting I took the carbs apart and found stock jetting which I didn’t expect since I bought it with the exhaust and power module my question is what size jets should I be running and could this be why I was bogging down at full throttle and had backfiring when cold after it’s warmed up it idles fine but seriously lacking in power
840 you will be up in the 170's to 180's on jets
depending on elevation and what the engine likes.
2 shims under each needle, 42 pilots, hole drilled in slide , running 2 - 2" snorkels and muzzy super pro dual exhaust
Where are you finding the jets and pilots any recommendations. I just got the shims today and are you running the same size jets in front and rear carbs
we have 182 front
185 rear
jetsrus.com
sudco.com
where we got our jets
1 ordered 1 of each size from 170-190
Discussion Starter · #6 ·
Are you still doing 2 1/2 turn on mixture screws. Also the 4 screws that hold the cover for the Diaphragm 1 was stripped have you replaced these because I can’t find them anywhere and wasn’t sure if I could just make a spacer for Allen head screws to swap them all out
yes, jet it properly.
do you have a foam filter? that would help, and then go bigger jets.
how big? start testing by half sizes. (easiest way, but is time consuming)
if you get a complete jet kit for the specific ride, it will come with the correct range.
1 - 8 of 8 Posts
