I've recently picked up the old mule from the family farm. Starting to fix it up. I'm wondering what is the biggest tire and wheel combo I can put on. Can I just lift the front or do I need to do front and rear? Do I need wheel spacers? Can I run the same size tires front and rear? Thank you.
The 3010 and 4010 are very similar. I put a 2 inch lift on mine and run 26x9-12 front and 26x11-12 rear tires. You could run narrower tires on the rear, but you give up some load capacity.
Sent from my Pixel 3 XL using Tapatalk
Are you running spacers on yours? I was hoping to run the wider width front and rear. Did you lift front and rear or just level the front up?
I lifted front and rear. I don't know if there is room for the 11" wide tires up front. I don't run wheel spacers.
