1 - 1 of 1 Posts
Hy. My name is Jason and I am new to the forum. I am tring to bring my 08 Brute back to life. I can't get the injectors to pulse. I have spark, fuel pressure and it will run if i spray fuel into the throttle bodies. I did a self check and found two codes 11 TPS and 12 air pressure sensor. I ohmed out the TPS and found it out of range (6.9 ohms ). Will this stop my injectors from pulsing. I had other issues that i fixed with that said i am ECU deep in this . So would greatly appreciate any help.
Thank you.
1 - 1 of 1 Posts
