was told it would go in reverse but when put in high it’s wouldn’t do anything at all any ideas what could be wrong?
All it has is reverse? If so, there's something wrong inside the transmission.
PROBABLY HAS TRANSMISSION ISSUES WITH BEAT GEARS.
Remove the linkage from the shifter or the transmission, then manually shift it into gear tyo see if she does anything.
