have an 08 brute force with fuel injection the bike is not cranking checked all the fuse's and they are all good pulled the plug off of the fuel pump and was getting a very dim light on the test light on the hot wire side of the fuel pump but getting a bright light on the fuel pump fuse now after checking everything i am getting nothing out of the hot on the fuel pump plug tried running a hot wire from the battery to the fuel pump and still got nothing then tried running a positive and negative to the fuel pump and still nothing seems that the fuel pump could be bad but regardless it is still not getting juice anyone have this problem before or have any clue what it could be?
