Hey guys, have a 08 brute force 750 efi quad that stalls out after slowing for a stop. I bought the quad non running and replaced the fuel pump. It now fires right up and runs good buzzing it around. Noticed the problem after a wide open pull down the roads. When trying to restart the fi light will flash on the dash.If i turn the key off wait a few seconds it will fire right back up?? Any help greatly appreciated.
Your idle rpm may be set too low, the reason for the stalling at a stop, this was a common issue on some of the '08s. You will need a tach to set the rpm's.
