Finally completed the build and took it for the first ride today (cbr1000rr motor in a Kfx700 frame). My only issue is that on the take off the rear end squats and I get some hop to the rear end. I let a friend ride it so I could watch it. You can see the chain and axle hopping on the take off. I don't know if the chain gets too tight and causes it or what. Any info on that would be greatful!
After about 30 minutes I got a little more comfortable and started giving it some throttle and ended up destroying my rear sprocket and sprocket hub
. It was all alluminum, looking for a steel set up now. Although after looking at some of the pieces I found, the screws that connect the sprocket and sprocket hub were not tight any more. So I also wounder if maybe a screw or two came loose and basically weekend the set up.
Over all I could not be more happy with it, looks sweet, sounds sweet hauls @$$!!
Again, any info on the wheel/chain hop would be helpful, thanks!
