i was wondering if any one could explain to me the process of replacing the electric starter? I had to replace mine recently and when I went to put the starter back on I feel like the spindle in the end of the starter isn't goig all the way into the little gear with the chain on the inside. Any ideas how to make sure it's in?
Did you take the side cover off and hold the gear in place? Or did you just take the starter off?
I made the same mistake, so a quick fix is this takes some arranging but works
Shut off fuel system, drain oil...
Flip unit on its side, use a screw driver to line the gear in the center of the starter opening and install the new starter will be tight seal flip back and bolt down
Hope that helps
