1 - 7 of 7 Posts
When going in the 8-15 mph range I’m getting a rattle that is as annoying as all get out. Thought maybe the bed floor or heat shield underneath the bed but eliminated that. Sounds more from bed area and left side but I’m known to be wrong (ask the wife). Anyone else have this issue or thoughts and/or suggestions.
Thank You
If it only happens when the back seat is folded up and the bed is extended, then it’s probably the folded forward back seat vibrating against the back of the front seat. Mine does this and I put a towel between the back seat and front seat and it stops the rattle.
So been trying to narrow this dang rattle down and still haven’t found the source but noticing more and more that it happens at slight decline and flat areas at lower speeds (8-12 mph). Anyone with thoughts?
If it sounds like mine possibly clutch. My 2020 is worse in cold weather. Have not seen a dealer yet.
Do a search, there are a few active threads on the subject
1 - 7 of 7 Posts
