1 - 9 of 9 Posts
So I have a bayou 300 4x4 that I bought for cheap while it was not running. I cleaned and rebuilt the carb, fixed some wiring and it fired right up and ran perfect. Rode it around and came back the next day to it not running. I found that the flywheel had somehow sheered the key on the crankshaft and the pickup coil wire got shredded too somehow by the flywheel. I put in a new pickup coil and key and it fired up but it will only idle now? The second I give it throttle it dies. It runs rich and or misfires with throttle but idles perfect. maybe because of the Chinese aftermarket pickup coil is wrong? I can’t find anything wrong with the carb and it’s squeaky clean with a fresh rebuild. The timing is good and I have 125 psi compression and good blue spark. I am at a loss on what the problem might be
1 - 9 of 9 Posts
