Hello all, new here,
I just picked up a 1995 Bayou 220 and it’s leaking a little from the drive shaft where it connects to the transmission. I know this is a tiny leak but I was wondering if anyone had any ideas about a relatively simple fix and whether it needs to be pulled completely apart or not. Thanks.
76195
76196
To fix it, either replacing the oil seal, or doing it the dirty way of throwing some silicone around the shaft interface, will require you pulling the driveshaft out anyway. Might as well do it the right way if you're that far in. This exploded diagram will help you out. (It's a 2001 diagram, but a '95 is the same)
