I have a 1995 kowasaki bayou 220 it locked up so I replaced the piston flywheel clutch etc it will crank for a bait 3 rotations then crank then it will shear it I have tried grinding compound and it still does it. The flywheel key way doesn’t look damaged. I’m just stumped.
I took it back apart re torqued it back down to spec and it did the same thing
Then there is something wrong with the fit. Hub stretched from being over torqued at some time or crank taper warn or damaged some way from spinning. Usually it's the hub though. What's the torque spec on that?
. Thanks man I got it fixed it was a missing bearing on the end of the shaft
