1 - 12 of 12 Posts
1996 kawasaki bayou 300 help!!!!!!!!
i have a kawasaki bayou 300 2wd and i just got it, the guy said that the carb. needed to be cleaned so i took it off took it apart and he had this stupid paperclip wound to look like a spring, so i replaced that and switched some stuff around and looked at the rest of the carb, everything is clean, the jets and the float are all good, the float floats and has no holes in it. it runs with the gas on at the petcock runs for a bit then comes out the bottom of the bowl so i shut the gas off and it runs better till it uses the gas in the line and its just like a cycle, and i cant break it lol. what else is left? oh and i have excellent blue spark
wish i found a 300 instead of the 220
just 1/8 inch square stock
Discussion Starter · #5 · (Edited)
and cut it to 2 inches and drill holes for shock mounts? same with the front? and an update on the situation, i had the hoses mixed around so it would just pour fuel in, its all fixed and runs in tip top shape!
do what i can haha
i used square and cut one side out of it
1 - 12 of 12 Posts
