I just bought This wheeler. It needs new wheels badly, they are bent. I am confused of what the OE front and rear rim size is. What size should I be buying aftermarket? The tires on the wheeler right now are fine so only rims are needed.
Most of the SRAs have a narrower hub-to-hub measurement in back then in front. As such the offsets are very different and the OE wheels will have an offset you won't find in the aftermarket market. However..most find that on a 7" wheel, using 2+5s on the back and 5+2s or in a 6" for the front, a 4+2 gets them pretty close.
75701
Would this work for the front? I put the year make model in and this is what it shows? Would the stock tire I currently have, fit on these?
75702
This is the rear size they sell that shows it’s for my wheeler. This seems abit bigger.
The back wheel shown above isn't any bigger, it's just the offset that's different.
Check some other online catalogs to see if they all agree on the offset needed.
