Just bought this bike and It runs but only by a pull start. I Turn on the key and I get a neutral light. Headlights and taillights work. Reverse light works if I put it in reverse.
In neutral if I push the start button the starting solenoid buzzes and the motor turns over slowly but not like is should. If I jump the two posts on the starting solenoid the starter turns the motor over faster(more normal). I've replaced the battery, starting solenoid and the starting circuit relay. I've checking the wiring for bad connections but found nothing broken. I disconnected the neutral safety switch just above the motor and jumped the red and green going to the harness but then nothing worked. So I reconnected the neutral switch. Not sure where to go from here. Seems like a faulty connection somewhere.
Please help.
Discussion Starter · #2 ·
Update, Okay I found that if I ground the Green from the Neutral reverse switch I get power but if I press the start button the solenoid still buzzes and the motor turns over slowly.
