Hello, I need to remove and clean my carb. Before I start pulling things apart, do i need to remove any of the plastic? Does it pull out right side after loosining the hoses? Any suggestions would help. Thanks,
Bill
I have an 87 mojave and i have found the easiest way to remove the carb. is to remove the plastic. and to make it even easier to get to i remove the fuel tank also. It takes me less than five minutes to remove my carb. Hope this helps.
You can also just disconnect the fuel line and leave the tank attached to the plastic and remove it as one piece.
Another tip is to be gentle unscrewing the choke from the left side of the carb. It's very easy to crack the plastic part of it or strip the threads when putting it back.
