Im bout to do a top end rebuild and wanted to know if anyone could list all the tools ill need so far i got torque wrench n sockets have valve spring compressor assembly lube
Depends on how far you're going with the re-build. Are you just having the cylinders re-bored for new pistons, or also replacing cam chains, new valves / valve guides, etc.?
Kawasaki workshop manual is available here and provides some of the special tools required for each location:
KFX 700 Service Repair Workshop Manual : Free Download, Borrow, and Streaming : Internet Archive
Note, if you're planning to replace the cam chains you'll need some additional tools like a flywheel puller and a primary clutch puller.
Thanks for the info not replaceing camchains but everythin else i am i now have a flex hone on way as well
