I have a 2005 Brute force that is not running right when I have a load on it with the throttle wide open. It will work fine idling and revving but when going down the road you can hear it in the exhaust. I took it to get the carbs synced and he said there was high compression but figured it’s fine since I had the upper rebuilt. I know I need a new choke cable since the brass piece on the front carb isn’t sliding in and out like it’s suppose to be. They said it was running a little rich on one of the cylinders. It will only get up to 30ish mph. Any ideas? Here are the specs.
Brute Force Teryx 750 85mm Stock Cylinders CP Cometic Engine Top End Rebuild KVF from AZ Quad parts,
OEM pilots and jets from outlaw racing,
2.5 in snorkel,
aftermarket electric fuel pump,
elevation is 738 above sea,
I’m going to order a new choke assembly, ignition coils and plugs and while I’m at it I will be doing another set of jets since one decided to snap on me when I was going though the carbs.
