I damage my gauge / speedo cluster on my 2008 750 Brute Force. Could somebody please tell me if a used 2005 gauge / speedo cluster would interchange?
Thanks Bill
Vendor
The 08 has the FI light, so they will not be a direct in functionality, I think the 05 is a 2 plug speedo?? I can't really remember.
the 08 has 1 square plug and additional 1 wire on the outside. I know that.
JOhn
The additional wire on the outside is for the FI light.The 05 cluster will probably work as all the pin connectors are the same on both meters,BUT... you will not have any indication of FI troubles. I would not recommend using it, look for a used 08-09 cluster or even better buy new.
Go with the correct meter, check the for sale items, I see allot of '08s being parted out on all the atv forums.
Thank you gents.
