Hi guys, I recently picked up a 2005 360 4x4 and when I got it the idle was erratic and it had some slight issues starting. Since then I cleaned the carb and adjusted both intake and exhaust valves, changed oil, and put in a new spark plug. After the valves the problem seemed fixed, I took it around the yard and no issues what so ever. Went to start it today, started right up but idle was funky again and under any throttle it wants to cut out and die, doesn’t rev at all unless it’s fully choked. What should I try next?
Fuel delivery problem of some type.
