good afternoon gentlemen; I have a 2007 kawasaki brute force 750; a while ago I was using my ATV regularly as usual; after using it, I kept it in my garage, for about 2 months; when I went to turn on to use; it did not turn on anymore; no juice in spark plugs; several people have tried to repair; but nobody knows what to do; I would like someone of you to give me a solution please, thank you very much.
Load test the battery and if bad replace it, inspect all battery connection and fuse box..as in remove the fuse box, turn it over and unplug the connector to inspect for corrosion. Double check that the kill switch is on and making contact. Inspect/test the key switch for operation.
the battery is new; the ignition switch is new, the pistons have good compression; when I turn it on, the starter works perfectly; I just don't have juice in the spark plugs, I think it could be the computer; or the voltage regulator; What do you think?
