I just bought a 2007 kfx 700 to replace the 04 I sold last month. I am having problems with the clutch. The bike has a green hmf, air box lid removed, k&n, and its been jetted. Previous owner. When riding, if left in gear it creeps forward. Not everytime, but most. Then when shifting to neutral, it grinds and goes into reverse but lights up N. slight bump forward puts it in neutral. Also takes a bit of force to come out of F when it's in "creeper" mode. Wanna fix before something breaks. Please help
Sounds like you need to adjust the belt deflection. Do a search there is a how to video.
Try adjusting your idle down a little. If your idle is set to high it will start getting into the belt. You should be able to adjust it with the knob just below where your right knee is when you are on the bike. It is a small black knob on a cable that goes to the carbs. If that doesn't fix it I would go with the advice from the previous poster.
