Can someone tell me if a 2014 750 brute force engine can be installed in to 2009 750 brute force without too much difficulty? And will all the other stuff that drives the quad work with the engine too. One post I read online said that I would need to do to replace the ECU and injectors plus some other I mentioned items. I hope I explained myself well enough. Thanks:cool:
If you used the 2009 intake system (complete), exhaust system and electrical system with the 2009 ECU, all you might need to to is add a programmable programmer as the heads and compression ratios are different. The rest should slip right in. Oh and if the engine came from one with PS, it will have the larger stator and "may" need a different rectifier/regulator.
