1 - 1 of 1 Posts
Bought this used for my son that is 5. What setting should the shocks be? They are cranked up pretty high right now from prior owner. I noticed the front wheels have negative camber, meaning the unloaded ride looks like tires are riding on the inside edges. I did replace the knuckle upper and lower bushings, the wheels were loose. Once I replaced these bushings they now have just slight play.
I want to make the ATV more stable / less likely to tip over so I was thinking about 2" rear wheel spacers? Anyone recommend? Which ones did you use? I see so many people do not recommend them on the front.
The shocks are original, but they are like $78.00 each to replace. Anyone know of an aftermarket that is direct fit?
Thanks in Advance
1 - 1 of 1 Posts
