Hello everyone i just purchased my first new quad ever. a 2009 prairie 360 4x4 in camo. When i brought the machine home i warmed it up on choke (temp was in the 30-40 range) and gradually eased off the choke and the engine slowly died. i know the machine has fresh gas in it. i restarted the engine and gently tapped the throttle to keep the rpm's up and used the choke to keep it running and then it slowly died again. i took it for a gentle trail ride and after about 30 mins of varying speeds 20mph and slower it stayed running, but seemed to be running hot. is this just a part of break in, or are the valves a little tight??:confused:
otherwise i'm pleased with my purchase. also is there a non cv carb available for this machine??
thanks
Idle
If it is under any warranty then let them know your problem ....If not it sounds like you may just need to idle it up a bit with the idle adjustment.
Good Luck!..............
ok thanks camo joe. i'd prefer to make the simple adjustments myself since the dealer i bought it from is on the edge of going belly up and their one service tech isn't the brightest.
i'm leaning toward the exhaust valve being too tight. i pulled the plug and it appears to be a bit whitish. i suspect a lean running condition. i read on another the valve spec for the exhaust is .15-.20mm or .18mm?? anyone else know for sure?
I have had two 360's and both were plagued with the exhaust valve tightening up,when the bike would get hard to stay running once warmed up I would have to readjsut the exhaust valve
