Will taking the drive belt cover connectors off make it run poorly? Would running it without the connectors mess something up? Cause now it seems to run bad.
Edit: Never mind, it was just a small mix up in resetting the belt. Didn't unplug the two wire after flipping the grey and black four wires, it runs great now.
I believe that it will make the machine think that the belt is having "Issues" and put it in LIMP Mode. This will allow enough to get home, but will run poorly. Plug it back in and see if it runs better. On the 2002 there is a 5 amp fuse that controls the belt detection circuit. Make sure that is not blown. I own what is in my signature so I have no history with any of the Prairie's...
