Bought an abused teryx last year with a run out of oil motor. Full rebuild but skipped the valve seals as I couldnt find my spring compressor and I was tight on time. Fast forward about 20-30 hrs and it’s starts smoking a little blue smoke then gets progressively worse especially on uphill climbs it would fog out bad. Compression test was great so I figured it had to be valve seals. Break and down and change valve seals. I ran it around the yard for about 45 minutes. It still smokes But not nearly as bad and it gets better as it warms up. My guess now is maybe the rings might not have seated properly? Am I missing something obvious?
