Long time since visiting the site. Been having as issue with my 11 brute 750 here recently. Under light load she is flooding wanting to die but under full throttle she runs great. I've changed plugs, fuel injectors, checked battery connections, checked for air blockages fuel pressure and I'm about out of ideas. Both plugs are extremely black. Could it be the computer going out? Any ideas would be appreciated since I'm about outta patience with this thing.
Check the pulse coil (CPS) per the manual, then check the actual coil voltages as well as the static and running battery voltages. I assume mechanically it good...ie.. proper compression and no leaky valves and doesn't use oil.
Mechanical side of things is perfect. No smoke leaky valves comp is good. From everything I've checked it leads me to it being electronic related. When it comes to electronics I still have alot of learning to do
