I have a 2017 Pro FXT and for some reason the 4wd will not engage and the rear lights will not turn on. It's got to be electrical but i cannot find a fuse or cut wire or anything. Does anyone have any ideas?
Have you found the small fuse box inside the plastic cover under the hood? When you remove the black cover you will see all of the electrical components. In the center is a small plastic box, the lid will open with a little force and there are some small fuses in there. To remove the cover just take hold of the tabs on either side and pull toward you.I have a 2017 Pro FXT and for some reason the 4wd will not engage and the rear lights will not turn on. It's got to be electrical but i cannot find a fuse or cut wire or anything. Does anyone have any ideas?
Have you checked your relays? The 4WD might have a relay.Yes Sir i removed them and checked them all but no luck. I guess i have to take it to the shop.Thanks Though
I just called my dealer and there is a solenoid in addition to a fuse.Yes Sir i removed them and checked them all but no luck. I guess i have to take it to the shop.Thanks Though
