1 - 13 of 13 Posts
Anyone have a good Idea on where to get a better air filter for the '21? It looks like they changed the airbox from Hester's video to have the piece molded into the airbox instead of it being removable.
Stock paper filters are not going to do it down here in the southwest.
Retro fit an old box in.
Doe the 2021s use a different air filter?
My 2018 FXR uses a Donaldson filter, same P/N as John Deere uses in their Gators that have the Chery engine.
Donaldson also sells an inner filter that fits inside the main filter. IIRC the JD diesel Gators have this.
It’s the same filter as before but I wanted one I could clean. And keep using considering how dusty it is here in NM.
The box is different from the previous years
John Deere came out with snorkel kit for some of their Gators. I heard it was due to complaints about the filter getting dirty too quickly. From the dust the tires make.
Discussion Starter · #7 ·
How is the box different? did they make the inner part molded in now?
Yeah, if you watch Hester’s video on the Zuni Filter that round ring he pulls out is now molded into the air box.
I’m going to buy the Uni Filter he recommends and see if I can get it to fit. It probably won’t
Check out K&N P/N KA-6201. They (K&N) say it's for the Mule Pro DXT, which is the diesel version, but the DXT uses the same Kawasaki P/N air filter as the MULE Pro FX, FXR, & FXT.
Washable and reusable.
I am not sure if an oiled filter would be bad for an EFI gas engine and that's why K&N only list it for the diesel engined Mules? Might be worth asking K&N if there would be problem.
Discussion Starter · #11 ·
I’ve run K&N’s on my gas trucks before without issue, just don’t soak them in the oil LoL like some people do.
I think I should be able to get that unifilter to fit since the stock filter didn’t change
Discussion Starter · #13 ·
Thanks!
Does the foam come off for cleaning?
Does it take a special oil?
So the other Uni filters I have you can take the foam off, and clean it and oil it like a K&N.
Most Powersports guys I know run these, with zero issues. I have one on my ATV, my KLR and it would be nice to get one for my Mule.
1 - 13 of 13 Posts
