First off here is video of issue.
So I bought a 2001 300 2x4 and have been loosing my mind over this issue for 2 weeks now.
Compression tested and had 139 psi. Replaced fuel filter and fuel line. Cleaned and rebuilt carb twice looking at everything to make sure it looked good. Has stock sized OEM jets. Replaced coil and spark plug. Borrowed a good working carb off my cousin’s 300 4x4 and it mimicked the exact problem. So I feel I can rule out carb.
Adjusted pilot screw from almost all the way in to 4 turns out with minimal change.
Airbox boot to carb has no pinholes or cracks that I could see.
The only time it runs better is if I block most of the air filter hole going to the carb. Which is what made me think it was a leak in that boot. Yet after fully looking it over, taping the ends, tightening clamps more, and spraying brake cleaner around everything while it idles to see if it revved up. NOTHING changed. Also btw it idles great. It’s just once you try and give it throttle you will get misfiring and it try’s and die.
I even swapped old coil back in and it has same issues. Besides tracing the wires going to the coil back. Idk what to do.
