1 - 1 of 1 Posts
2007 Kawasaki Mule 3010trans4x4
Bought a machine that both the drive and driven clutches are toasted. Sheaves are concaves, not straight tapers. Machine was run with incorrect belt causing excessive wear. New belt helps but still not correct. I have a chance to get a drive clutch off a Teryx 750, are they interchangeable? i realize I would likely have to change springs, just wondering if the rest is the same. Also, is there no aftermarket clutches for these units? Seems all I can find are factory replacements, which are on back order with no real delivery time available.
Thanks.
1 - 1 of 1 Posts
