1 - 7 of 7 Posts
4 Speeds on 12" douglas wheels, 24" pro wedges, 22" 4 snows, dune tracker fronts...
24x11x9 Pro Wedge 501's on Douglas 125's....Maybe 2-3 passes down the track on them. $225 shipped.
12" douglas wheels with 26" 4 speeds. 20-30 miles on the set. $500 shipped
21" dune tracker fronts on stock wheels.....1 wheel has a bend, could easily be popped out with a bit of pounding. $100 shipped.
25" Skat smooth buff fronts mounted on stock prairie wheels. Never ran them....they slow leak like most skats. $125 shipped
22" 4 snows.......don't have a pic but they are in good shape. No wheels Ran them for a couple of races. $75 shipped.
All prices are for the 48
Did you get those 24" Pro Wedges off eBay this past summer? That is the only other set of those that I have ever seen other than the ones you are selling. I had thought about buying them. Are they really 24" tall when aired up or taller? Some of the tires of that type seem to grow more than normal when they are aired up to 3-4 psi.
What are the two bolt patterns that are in those wheels? It appears that the larger one is the 4/137 Kawie pattern. Is the smaller one 4/110?
4x110 and 4x137.........Not sure if I got them off ebay or not. I might have. The size varies a lot with air pressure but these measure right around 24" 4# in them.
man,... those wedges are nice... ugh..
I take it the wheels on the 4 speeds are 4/137 bolt pattern. Is it possible to get a wieght on one rear and one front tire/wheel combo?? This might make a great drag combo for the teryx.
1 - 7 of 7 Posts
