Went for a ride in some snow Wednesday, and I was cutting through a big bank in 4wd and suddenly heard some nasty grinding and popping noises, and lost 4wd. My girlfriend winched me out of the snowbank, and I limped home in 2wd thinking that either my actuator had gone out, or the block and pin had finally worn down enough that it wasn't moving the slider anymore. But when looked into it today, I was surprised to see the actuator working fine, and the block and pin looked great.
The bad news is that the front shaft looks shot, and the bearing and coupler in the front diff have more movement than I like to see!
So, what am I looking at here? How can I fix this? Is it worth buying another shaft coupler and hope that it won't spin around the teeth on the propellor shaft coming out of the engine? How much work is it to replace that shaft? How hard is it to replace that coupler bearing in the front diff? 26,000 miles and I've never had to do anything with the diff before...
