Well I took the brute to the shop a while back due to a bad KEBC and the computer under the seat that controls the 4wd as well as the toggle switch. They replaced both and now I'm having a new issue.. The bike just won't shift from 2-4wd sometimes.. Sometimes it will and sometimes it gets stuck in 4wd for a while when it engages. I've been riding with it in 4wd all the time and it never fails. But if I do shift it out I have to shut it off, sometimes unplug the computer under the seat and try a few times before I'll work again. Sometimes it just won't engage at all. Seems like it has more of an issue coming into 4wd that out. I'm having no flashing lights on the display
Anyway, assuming it's not the three replaced components that only leaves the Actuator in the front diff and the speed sensor. Any thoughts on which it could be? I really need to get this 4wd squared away.
Thanks for your help
