I have searched and when I type in (4x4 not working or 4wd not working or even 4x4) it says cannot find so maybe by pc was the problem I dunno. Just about to purchase another prairie from my friend and his 4x4 quit working after we put a new cv joint in. It doesnt flash and you cant hear the actuator lock in. It just stays in 2wd, what is every possible problem. If you want make this a sticky unless it already is. Thanks.
check...........?
Check the fuse.........Make sure the connections are plugged in correctly (not dirty, no bent prongs, cut wires etc.)......Make sure the battery is fully charged..........Could be the 4x4 switch...........Did it work right before the cv joint repair?
The actuator may need serviced (cleaned and checked)..........
Yea, its worked fine before he took the cv joint out and put the new one back in. U think he unplugged something? What can I check by the cv half shaft? Thanks
