OK, I swapped a 2008 Brute force 750 engine into a teryx, after converting it from EFI to a caborated system it finally runs great! Now the next leg of this journey is,
where do the vaccuum lines for 4WD attach? I cannot find where the vacuum lines hook to the engine. any advice, or page in the service manual would be great.
The 4wd system is electric...like all other Kawasakis' as far as I know. The only tube coming off the front diff is the vent.
On the Teryx they use a vacuum actuator system on the brute force it is completely electric and the difference is on the cylinder head I’m pretty sure there are connections right at the base of the intake on the cylinder heads
