Your 2wd and 4wd lite should be blinking back and forth. there is a time delay 2 tell u witch one is witch.
Your 2wd and 4wd lite should be blinking back and forth. there is a time delay 2 tell u witch one is witch.i have a problem,my actuator is working when i put 12 volts to it but its not getting a signal from my switch,also my bike is not making that wining noise any more and my engine brake is not working ,that motor in there also works when hooked direct. are all there problem connected.
lite is not flashing its says 2wd and thats it my actuatar when before and it was flashing but not this timeYour 2wd and 4wd lite should be blinking back and forth. there is a time delay 2 tell u witch one is witch.i have a problem,my actuator is working when i put 12 volts to it but its not getting a signal from my switch,also my bike is not making that wining noise any more and my engine brake is not working ,that motor in there also works when hooked direct. are all there problem connected.
