Was working fine then battery went out. Put in the new battery and 4x4 hasn't worked since. I have swapped out the actuator controler and it is not the problem. I swapped out the 2x4/4x4 switch also with no luck. I tested the actuator per the service manuel specs and it checks out good. The only electrical component left to check is the speed sensor. Any other thoughts on what I should check?
