1 - 9 of 9 Posts
6-degree key whot is it do ????
and how can i do that ?????
Advances the timing 6 degrees..
It involves pulling the side cover and flywheel..it does need some special tooling too.
Discussion Starter #3 (Edited)
wot kind of parts do i need and how match $ ????
and any other mods need's to be dot in order to work ????
i believe you have to run then factory cdi
Nope. You can stack the CDI and the degree key. But DO NOT use any nitrous with the timing advanced.
Discussion Starter #6
1 - 9 of 9 Posts
