21 - 40 of 49 Posts
Discussion Starter #21
I am running both on my 800 just wanted to change out the 4* to the 6* and I have two friends with vertualy stock cows that wanted 4* keys so I told them I would look why I was getting me a 6* key for my green V & #2 picture is correct for any one that wanted to know
Picture two is how I had it installed in my 750.
I hope those guys are good, I have just ordered one to be sent to the uk.
I am assuming he means either atvtrickstuff.com or 700v.com
They are both top notch, they will do you right.
sorry atv trick stuff.
Jesse (VENFORCER on here) has been nothing but good to me.
I buy from him when I can.
Jesse..aka...AtvTrickStuff is top notch, you'll be very happy.
I will be installing the 6* key from him this week, and changing to a BF flywheel also...
I am going to install as per photo 2...
the key ADVANCES the ignition...
the crank rotates counterclockwise...
therefore photo 2 makes the most sence to me...
but it can be a little confusing.
JMHO Ed3
You can use a harmonic balance puller too
Hi, 2 questions as my 6 degree bit has turned up.
1, how do i use a harmonic balance puller instead of threaded one?
2, what gains should i expect by fitting this?
thnks
6 degree
Hi all
I have fitted the key this evening, BUT it doesnt seem to idle properly unless i increase the idle speed, am i missing something do i need to tweek something else after fitting?
The only mods on my 700 is a slip on end can from a motorcycle (which pops when i release the throttle) and the 6 degree key
thanks
Discussion Starter #32
thnks
that would depend on what you have already done to your quad ???
You can make a signature at the bottom of your page and tell what year and mods done so far.
Kenny
Did the 6* key today, the jetting needed adjustment afterward. I went from 150/155 to 155/160, and opened up the idle mix a bit. Woke it right up - the front tires don't touch the ground as well as they used to:D
mods are as per my most recent post!
Oh good!
I think everyone should delete thier signatures, and go back to the most recent posts to find the mods for that quad.....:rolleyes:
POST A SIG DUDE....it's not too much to ask when you're getting FREE HELP...:p
Yeah!---And don't get GarDog all riled up anymore:clap::clap:
Kenny
Just go to Quick Kinks, (top right of page), then click on Edit Signature---Then you can start with what year,color etc.
Kenny
:lol:
:lol:
:lol:
Thanks Kenny....I prolly woulda been nice...
if he hadn't yelled at you with the exclamation point...!!!!!!! WTF?
ok ok, i see your point, but please see my point! i asked a question and if the whole question was read then you would of known what mods i had thats all!
right its done. now can i have somehelp? Please????
21 - 40 of 49 Posts
