1 - 8 of 8 Posts
Got a clutch from mother clutcher and I'm trying to raise the rpms. I bought 56g belly busters because I thought my 02 650 would have 58g. Well when I opened my clutch. It has 72g meights.
What kawie has 72g weights?
I put 2 56g in but haven't got a chance to run it. So who knows where my rpm is gonna be lol
The spring inside that clutch wasn't colored.
I went to a maroon spring. So I should probably put all four 56g belly busters inside and call it a day?
71g definitely won't help me raise my rpms
71s with any spring lighter then the RED probably will close even at idle. Yes, put the 56s all in with the maroon spring. I ran the 56s with the Pink only because I wanted a little lower stall.
Im curious to see how this clutch holds up ?
  • Like
Reactions: Swanny52
Discussion Starter · #7 ·
Discussion Starter · #8 ·
[/QUOTE]
I put all four 56g weights and the maroon primary and black secondary. My peak rpm down the track was 6100.
How is this possible? I thought lighter weights raised rpms?
1 - 8 of 8 Posts
